1 - 10 of 10 Posts
Are roller spring perches that much better than new/stock perches? I am curious if it is worth $300 on my drag only 3300 lbs stock suspension 67 mustang that runs 9.90's. It lauches the front wheels a couple feet off the ground and seems to drive fine with the stock perches.
Thanks for the help
Justin
Read up on Vintage Mustang Forums and/or Corner Carvers. John (Opentracker) on VMF invented them and can tell you what to do. And... they're easy to make yourself with a hole saw and a mig.
I couldnt justify the price but I wanted something moved more free than the stock rubber. I machined some bronze bushing for mine and they move real free and there is no deflection and the price was much less..........ron
also bushed the a-arms
Thanks for the replies.
I like the idea of making my own, so I might have to give it a try.
Justin
bbstickstang did you have to limit the front end travel? because it seems my front wheels drop an awful lot compare to yours during the launch.
Justin
Justin
Yes Justin i did limit the travel but only by about an inch. With no limit on it . it pulled the bottom mount off the comp eng shock twice.
Did you use a chain/cable? Where did you place it?
Thanks for your time
Justin
I used a chain and bolted it to the upper bolt on the shock tower by the shock, and then i have a hole drilled in the upper a-arm( note extra hole on a-arm between perch holes and ball joint)............rws
1 - 10 of 10 Posts
