1 - 8 of 8 Posts
Do you have any more info on it or maybe a link to the guy's website. My dad has a 67 Cougar he's putting a 351W/AODE into. Would this work?
Definitely interested...
ronmorrisperformance.com look under online store at transmission parts. What I have is code #7121 crossmember and code #7113 trans mount. Should work for your application but u could call them to be 100% sure.
I believe the aod mount is in a different spot moved back from c4 a few inch's. This mount bolts to factory holes and moves trans mounts back so you can mount aod with out having to cut,weld and drill new holes.
1 - 8 of 8 Posts
