1 - 10 of 10 Posts
Took the car out for the first time it hit the rev box at 6200rpm at 3/4 track the time slip say i ran 98mph the calculater say i should run 117mph
I HAVE A C6 3800 STALL 4.86 gears 33 tires but they measure 31inchs before changing gears I want to make sure I'm not missing something thanks for any advice
Converter is new but how can you tell if it is slipping
Honestly I have no idea but you’re math is correct so something in the driveline must not be transferring all of the power.
I know it sounds like a stupid question but are you sure it’s not a 5.86 gear? The math is right if it is.
I double checked the gear Its a 4.86 I'm guessing clutch is slipping in 3rd gear thanks for the help and to any 1 with any advice
What's a good rebuild kit for the c6
.006 x engine rpm x tyre radius / gear ratio = mph
.006 x engine rpm x tyre radius / mph = gear ratio
been using this forever and its pretty accurate for 1/4 mile
My calculator returns 106mph with an auto trans (10% slip at WOT, non-lock up stock stall conv) and 118mph with a lock up converter (no o.d.). So, 98mph with a 3800 stall converter is ~17% slip.
i run a TAD, converter driven bruno, in front of a B&J 3 speed, all this is behind my ford hemi.
dont bother with stall. just call a good converter shop, tell them what you have. let them build for your application
The converter is a custom build
Will the alto 026757hp work in both high and low drums if not what packs do I need
Planing on using 2 alto 026757hp packs and 1 026755 pack
1 - 10 of 10 Posts
