1 - 11 of 11 Posts
i took this crank out of a running engine , all the bearings looked new when i took the engine apart, this crank looks good !
$100.00 plus shipping
cubic inch
ft302351 said:
what cubic inch will this crank make? and with what rods?
If you go to Engine tech Archive, there is a thread called bore x bore x stroke chart. It does not list the rod length but will give you the cubes.
Re: cubic inch
BBFCJ said:
If you go to Engine tech Archive, there is a thread called bore x bore x stroke chart. It does not list the rod length but will give you some idea. Rod length and compression height coincide.
Yup, it's a sticky up at the top.
1 - 11 of 11 Posts
