· Registered
Hello, I was wondering if this damage is repairable by just work with a dremel to smooth things out or if I need to go another direction for it? I did not cause the damage, they are pictures from a used head.
Thank you for the advice!
Gas Circle Auto part Automotive tire Metal
Gas Font Auto part Metal Circle
· Premium Member
Deck the cylinder heads to minimize issues with the quench pads.
Knock down the gouges in the chamber
Check valves so see if they are bent.
Check seats for damage.
Call it good.
"EMC 2006" 3rd place finisher
Custom ground cams
Customized crate engines
ParklandAutoMachine.com
R-H-P.biz
(253)-988-6648
Parkland Auto Machine
· Registered
Discussion Starter · #3 ·
Call it good.
Custom ground cams
R-H-P.biz
(253)-988-6648
Thank you for the quick response!
· Premium Member
It appears that the damage is confined to with in the firing ring of the head gasket DOUBLE CHECK and address any damage in that area.
The deck must be in good condition where the firing ring seals.
Custom ground cams
R-H-P.biz
(253)-988-6648
