What carb do you have? Sounds like the butterflies are not set correctly.
Yes your right the light silver springs would be good for that combo.Yeah nuclear that sounds like a plan, I was actually thinking installing the blue one to have 21 cetrifical advance, but I can try the blk one also. What you think about installing both light silver springs? The eng is in a mud truck with 40" tires and that 3500 stall so I would think the sooner the better with the advance or am I wrong? I am also kind a wondering on the transistion slots on the carb, maybe with that new cam they might be set up wrong.
I have to agree with him that cam should pull~12-14 inches of vacuum. Are your valves set correctly? Did you replace the carb gasket when you pulled it? I would check the gasket first before installing a new pv.That cam should make more vacuum than that.
