Finally, I have located a suitable parts truck for my Dana 60 front axle, which is a 94 F-350 turbodiesel. I plan on running a reverse shackle setup in the front using the stock F-350 springs, similar to the sky manufacturing bolt in piece. I will manufacture it out of 4" OD 1/4'' wall thickness square tubing to save time welding plates together.
http://www.sky-manufacturing.com/new/detaproduct.php?id=162
I plan on centering the front leaf spring bolt directly underneath where it would have been positioned on the front shackle originally, and drilling the hole 4 inches underneath the leaf spring bolt in my new support. In the rear I will bolt up a rear axle stock shackle in the existing bracket.
My question is, am I correct to assume that in order to raise the truck 4 inches I need to repostion the hole at the front of the frame exactly 4 inches below the original mounting postion?
Does anybody have a sky kit or ORU that can measure the drop down from the old mounting point?
I think I have it figured out I would just like to hear from anybody who has already done this to give me some alignment pointers, as I will be building the front leaf support this coming week.
Its an 83 F250 2wd that it will be going on. (I already have the rear leaf mounts to install)
