Status
Not open for further replies.
1 - 14 of 14 Posts
Sold
Price reduced from $599 + shipping to just $575 including shipping.[/b
Brand new Probe p/n 10330-030 forged flat top stroker pistons. 4.39 bore, 1.35 c/h, 0.990 pin.
These pistons will fit the following stroker kits:
  • 4.3 stroke 521 with 6.8 rod
  • 4.5 stroke 545 with 6.7 rod
...and produce the following approximate compression ratios...
  • 521: 12.9:1 w/ 75cc head; 10.75:1 with 95 cc head
  • 545: 13.5:1 w/ 75cc head; 11.2:1 with 95 cc head
Also included in this package deal is a brand new Total Seal 1/16-inch ring set, p/n CR269030, to go with the piston set.
All parts are in brand new flawless condition. Retail for the above package deal cost about $700 plus shipping.
Sell $575 shipping included in the lower 48 (all others please inquire for shipping quote).
Sold
Paul
the pistons would be too far down in the bore if you tried to use a stock crank- not only that but theyre floating pins not pressed fit and theyre the wrong pin diameter, so they wont go on stock rods even if you wanted to try. they will work with stock heads if you use the proper rotating assembly though
1 - 14 of 14 Posts
Status
