1 - 7 of 7 Posts
I have a Holley Black electric fuel pump, has maybe 10 passes, $100.00 shipped. Moved up to a Barry Grant
Feed your need for fuel.
These Black electric fuel pumps from Holley feature an improved design for street and strip applications, a new lower housing casting for enhanced fuel flow, and a tumble-polished billet look with the distinctive black logo. These pumps have a 140 gph flow rate, only draw 4 amps, and have a maximum pressure of 14 psi with an externally accessible pressure relief valve. They weigh only 3 lbs., and include a mounting bracket. These pumps are compatible with alcohol or methanol fuels.
Also a Granatelli in tank fuel pickup for 86-93 mustang to run a external electric fuel pump 45.00 shipped.
Move your electric fuel pump out of the gas tank.
These Granatelli Motor Sports fuel tank pickup assemblies are designed to eliminate any restriction that could be caused by trying to pull fuel through the stock pump and hanger assembly. They feature a pickup tube size of 5/8 in. with a -10 AN threaded male attachment, and a return tube size of 3/8 in. with a -6 AN threaded male attachment. The pickup assemblies require the use of an external pump to supply the fuel
contact Mick at [email protected] My Ebay handle is huntingmag44 if you want to see my perfect feedback. Thanks
Yup still have the black pump, 100.00 shipped via USPS priority mail.
I forgot I also have a Mallory Comp 140 inline cannister style fuel filter that was only used with the black pump and is like new as well. I would take 60.00 for it shipped to your door. Also if somebody bought the pump and filter together I would throw in braided line and fittings to connect the two.
Don't be afraid to make offers!!!!!!!!!!!!!!
I need the pick-up can you call my cell with address to send money order? Let me know and I will send it right away. 405 301 5163 home number 405 279 2675. Thanks Tyler (bigblockfox)
1 - 7 of 7 Posts
