Used great shape, aquired on a trade deal, Lem specs $225 shipped in the US
Serial # G 0092-05 Spec Card# 08691705
Part # 34-000-9 CAMSHAFT, FF FORD 429-460 ROLLER
Core C34-9A CAMSHAFT BLANK, FF FORD 429-460, 5160
Grind # FF 4026R /4031R R 110
DURATION @ .050 INTAKE 272 ROCKER ARM RATIO
VALVE ADJ INTAKE .026 DURATION @ .050 EXHAUST 280 INTAKE 1.73
VALVE ADJ EXHAUST .028 LOBE LIFT INTAKE .4210 EXHAUST 1.73
VALVE LIFT INTAKE .728 LOBE LIFT EXHAUST .4210
VALVE LIFT EXHAUST .728 LOBE SEPARATION 110.0
DURATION .020 INTAKE C/L 106.0
TAPPET LIFT INTAKE 308 CAM ADVANCE 4
TAPPET LIFT EXHAUST 316 HYDRAULIC
VALVE TIMING .050 OVERHEAD CAM N
VALVE OPEN INTAKE 30 JOURNAL DIAMETER STD 2.124
VALVE OPEN EXHAUST 74 RECOMMENDED VALVE SPRINGS
VALVE CLOSED INTAKE 62 DEPARTMENT P
VALVE CLOSED EXHAUST 26 SPC INSTR FOR CUSTOMER
