1 - 13 of 13 Posts
Hey Guys,
I have a solid roller cam with solid lifters non aggressive profile 258/262 @ .050 and 650 lift. It is 180 closed 480 open asking what I could expect for miles out of the roller bearing lifters. It will be mostly street driven.
You need to tell us what brand your using if you want good opinions.
In my shop we have used Crower Hi-Po and Isky and BAM.
Very well made and all three are family owned companies.
Stay away from the garbage from Memphis.
Hey Guys,
Quality lifter as said ^^^^ at those spring pressure's 30k miles easy. As long as you check lash once a year.
Cheers, Bob
been changing the comp lifter out after 8 to 10,even 12 years, never one to fail, lot more cam then you, some of these guys put 30,000 miles on them, One guy has more.
Some of these lifters have been in 5 or more diff ENGINE builds,
All are have been COMP CAMS SOLID ROLLERS
180 closed is not enough
@BOSS 429 what kind of spring pressures do you recommend running with solid rollers on the street??
we run min 350 + closed,
Werecow, I'm running 200lbs closed and 525lbs at max lift. Rev limit is set at 6200rpm.
rev limit 6200, lol on a BBF?
I was asked a question. I have many out there, More than a few with a lot of miles,
You do what you want.
1 - 13 of 13 Posts
