Status
Not open for further replies.
1 - 7 of 7 Posts
· Premium Member
THIS BLOCK IS SOLD
Stage 1 prepped D1VE block. This block has been thermo-cleaned, inspected and passed mag check, Stage 1 oiling mods executed throughout (blend casting flaws, enlarge pump-to-filter pad to 9/16-inch and blend, blend rear valley drain-backs, create front valley drain-backs and blend, add distributor gear lube gallery), and sonic checked (sonic check sheet will be included). Currently at 4.39" bore. In a properly tuned, naturally aspirated combination, we see no reason why this cylinder block wouldn't support 750+ hp at 4.42" overbore, and be perfectly usable up to 4.44" bore, and that's a conservative rating (lower hp numbers may allow for larger overbores). There's a lot of service remaining in this fully inspected cylinder block.
Our retail pricing is normally as follows:
  • D1VE 2-bolt block (fresh tear down): $125
  • Thermoclean & mag check: $125
  • Stage 1 oiling mods: $200
  • Sonic Check: $75
  • Grand Total: $525
We are discounting this block to just $400! Shipping is exrtra, of course. Also, we can deliver/rendezvous pretty much anywhere in California.
Call or PM if interested,
Paul
310-435-1900
THIS BLOCK IS SOLD
· Premium Member
Discussion Starter · #3 ·
Thanks for the bump.
I want to add that not only do I feel that this block's cylinders will support 750+ hp in a properly tuned engine, but with a little offset boring it can go to 4.500" bore. :)
Paul
· Premium Member
Discussion Starter · #5 ·
Paul how much to ship to Michigan 48180 and can you bore it 60 over thanks Joe.
Joe,
It would be best for your local machine shop to do the entire cylinder boring process (with pistons in hand) and not finish up a previous shop's efforts. Therefore, we prefer to sell you the block as shown and further preparation is then up to the end user and (hopefully) completed under one roof.
Shipping from the San Francisco bay area to Inkster Road, Taylor, MI 48180 (you pickup up from the dock) = $180 shipping charge. We crate it for free.
Please call with further questions,
Paul
310-435-1900
1 - 7 of 7 Posts
Status
