1 - 13 of 13 Posts
I am wondering how to tell a steel crank apart. Casting #'s? It was in a 27' motorhome. I have heard that it should have one, because it has truck rods and it's application. Any help on this? Thanks,
Mike
The only Ford Steel cranks came in the heavy truck motors. They have a larger front snout. Your motor home almost certainly has a passenger car type 460 which will have a cast crank.
dkp
Forge I.D.
Standard rule of thumb; castings are from metal poured into a mold and will have a fine (1/8" or so) line on the unmachined surfaces.
Forgings are billit material hammered into a die to shape material and will have a wider (1/2" or so) seam on unmachined surfaces.
You can see this on crank shafts, spindles and even on connecting rods of small engines.
I didn't think it was, but figured I'd ask to make sure. A steel crank would have a different timing cover and balancer....a buddy had an F-700 crank and it was totally different......damn....that sucks. O well, Thanks for the responses guys.
Mike
I'd like to see that process..........................
G ;)
"With the near-molten steel placed in a forging die, a hammer press slams the die with about 240,000 lbs. in not one but multiple steps"
I knew cold forging would be difficult for a crankshaft ;)
G
1 - 13 of 13 Posts
