Stefs oil pan (wet sump trap doors etc in it.. ) This is on and fits A460 Block
Weaver single stage belt driven oil pump, with external filter all the AN lines and fittings for this set up.. Also has both pulleys etc.. only thing you need is a belt for your fitting.. will fit in fox body etc .. the parts are used but still good condition(so no stupid questions) You can not run a oil pump inside this pan unless you ad on to this pan. im keeping all of this together.. i've decided not to run this set up but just run a kasse pump
$1000 shipped for all.. OBO no low ball
