Gilmer belt drive 429/460
Home made tall cast aluminum valve covers 429/460
Sfi approved harmonic balancer stock 429/460 snout
Let me know if you think you may have some thing
I have a brand new, never used CAT HBF-460 dampner.
FORD 429/460
FLUID DAMPER FORD429/460,7.25"D/2.36"H,'68-97
SFI FLUID DAMPER
CAT fluid dampers are manufactured from forged 1025 low carbon steel housing and injected with high viscosity silicone fluid. A nylon ring and nylon position guides allow the steel inertia ring a rotation freely inside the housing. The steel inertia ring rotates harmonically with the engine and absorbs the torsion vibration from the rotating assembly at any frequency and RPM. It thus extends the life of crankshaft and bearing and allows the engine to produce more power and torque. All dampers are tested to 12,500 RPM for explosion proof in compliance with SFI 18.1 Specification
I'd sell it for $65 plus shipping. Thanks.
Ron
