if i run a Diamond piston made for 4.3 stroke crank with a 6.8 rod with a compression height of 1.350 for use on a 10.300 block, could i use that same piston with a 4.5 stroke crank and use a shorter rod like 6.7, as long as i use the same block? it appears to me that its the same piston. assuming bore sizes are the same.
