Guys, I've run into an electrical issue.
No key or button/kill setup yet, I just want this motor to crank over...
Two brand new solenoids, so, that's ruled out. I'm just clueless as to how to wire this up right.
One large side bolt goes to Positive battery Terminal. Ok, easy enough
Other large side bolt goes to starter wire (which cranks when given voltage, ruling that out as a problem).
But these other two small screws.... one's labled S, the other I.
I figure one is switch, one is ignition.
What do I need to hook to these other two small screws to get my motor to start?
Here's a diagram of the solenoid I'm working with
Thanks for any help you can give!
