When using the OEM or stock replacement soft iron cam thrust retainer plate you MUST USE an Iron top gear OR a billet is permissible when a roller thrust bearing is present as on the summit part.
That is a repackaged timing set made by SA.
We use that set in engine pro with either a Rolon OR Ewis chain as they are better quality than the BS entry level chain.
"EMC 2006" 3rd place finisher
Custom ground cams
Customized crate engines
ParklandAutoMachine.com
R-H-P.biz
(253)-988-6648
Parkland Auto Machine
Custom ground cams
R-H-P.biz
(253)-988-6648
