Status
Not open for further replies.
1 - 20 of 60 Posts
Tall fabricated valve covers
Tall Fabricated Aluminum 429/460 Valve Covers
-Long bolt design to maximize clearance for stud girdles, etc.
-Mounting hardware included
-Work great with OEM, SCJ, P-51, and AFR heads
-Clear anodized for corrosion protection
-Thick gasket mounting rail to maximize sealing.
Discussion Starter #7 (Edited)
Carl, are the valve covers still available?
Currently only have short-bolt style in stock. Will be re-stocking the long bolt style as soon as they're available from the supplier.
any idea on how long? and what do the short ones look like? and do they fit stud girdles?
Photo attached.
Probably looking at mid-August or so on the long-bolt style. I've never used the short-bolt style with stud girdles, so I can't say one way or the other. I do know the short-bolt style won't work with SCJ/P51 heads due to the location of the exhaust valve spring.
Discussion Starter #12
but the long bolt style will work on SCJ/P-51's then put me on the list please for mid Aug.
I'll post here when they're back in stock, so you should get a notification in your "subscribed threads" folder.
Discussion Starter #14
Any knowledge of the short covers on the C-460 Heads?
Thanks,
Mark J
These covers are both the same height. Short-bolt style just has cutouts for the shorter bolts.
1 - 20 of 60 Posts
Status
