1 - 3 of 3 Posts
I am debating going a different direction with one of my current projects. If I can get a commited buyer in the next couple weeks that will make up my mind. If not I will continue going forward with this project.
I have the following parts for a small block windsor they are currently planned for a 427 ci windsor.
RHS aluminum 20 degree 62cc chamber 221cc intake runner CNC ported . These heads are equipped with Ferra F6203 2.08 intake valves and Ferra F6205 1.625 exhaust valves. They have 1.500" 10deg tool steel retainers, valve springs are 944-16 comp springs, 530 seals viton, valve spring installed height of 1.910, cut and decked for a 30 RA finish, comes with comp part number 4512-26 7/16 rocker studs. look at the chart below for the flow numbers.
INT. EXH.
.1 90 60
.2 150 100
.3 200 140
.4 240 170
.5 270 190
.6 300 210
.7 326 230
The cam is a custom ground Comp Cams Mechanical roller lift - .726 intake .704 exh 110 lobe separation duration at .050 276 intake 282 exh. Roller lifters comp cams part number 838-16.
Port matched super victor efi intake and a set of black & red Ford Racing valve covers. All of these parts are new never been ran or bolted on.
I also have an AEM 1900U-0134 stand alone programable engine management ecu and harness as well as o2 sensors and the whole works. This system can control N20, boost, trans, trac control, ect.... The AEM computer is used but in good shape with a lot of extras.
I have over 7,000.00 invested I would take any reasonable offers, or partial trades on BBF rotating assemblies, dominators, trick flow mafia intake, Heads ect....
All items are located in Mount Ayr, Ia either pm me here or call 641-344-7464. Please no low ballers or tire kickers.
Derrick
would sell the victor intake and if so is it for 9.200 or 9.500 deck thanks.
I want to sell everything together if I sell at all like I said before if I don't have interest withing a couple weeks this engine is getting put together! it is for 9.2 deck tho.
Derrick
1 - 3 of 3 Posts
