Hey Guys,
I am looking for advice from folks that have experience with this engine combo. I got this from a family member of someone that passed away and they knew less than nothing about the engine. It is an old build and was in an all fiberglass 65 Mustang bracket car with a glide (the car is gone). I kept the engine and tranny.
It is a 547 D0ve block, bored to 4.5, short filled. It has stock 4-bolt caps in the center. I don't know what brand of crankshaft (4.3 stroke), but it is internal balanced, Scat H-beam rods w/ 8740 bolts, and BME flattop pistons (.010 in the hole). The block is o-ringed / copper gaskets and has ARP studs. The passenger side lifter bores are bushed, and the inside is painted that reddish orange.
It has a Lunati Solid Roller Cam. Advertised Duration (Int/Exh): 287/295 ;Duration @ .050 (Int/Exh): 256/264 ;Gross Valve Lift (Int/Exh): .672/.672 ;LSA/ICL: 108/102
The heads are BBF-1 A460s. I sent the heads to Charlie because of some bent valves (my fault). He worked his flow magic on them and installed new Ti valves and springs. It has a Trick Flow dual quad 4500 tunnel ram with 1050s on it.
I want to put this in a 3400lb 85 T-bird for street/strip. No power adder. Probably a Grid ignition. It looks like it will be right at 12-1 compression. Can I get by on pump gas? How temperature "unfriendly" is a short filled block in this situation? Is the head / manifold even doable in a street situation (seems like race only)? Is there a better cam choice for this combo (as street/strip, and/or if I went race only)?
