1 - 10 of 10 Posts
Guy,s
Picked up a 1988 T-Bird last weekend and looking at putting my 466 with a c6 behind it.
I have not messed with these chassis so I know nothing about what works and what doesn't. I has a manual steering rack with a 351w c6 in it now. I would like to stay with
the motor mounts instead of a engine plate if that helps? I know Lem has a good deal on oil
pans right now I'm not sure if it would work or not? What type of headers yada yada yada.
Motor does have a set of tfs street heads withthe exhaust ports being a little higher than stock location not sure if that's a problem or not. As always thanks for the advice.
Steve
The 88 T-Bird is the last year of the Fox Body T-Birds,i had a 88 T-Bird that i put a 460 in.I have some pictures of it but not alot.If the one you're looking at had the K-Member changed to a aftermarket that would be a plus,since the Mustang K-Member was different than the T-Bird in 1988.The factory T-Bird K-member in 88 had motor mount bolts that went paralell to the frame rails.In order for me to use the 460 swap motor mounts in the T-Bird i had to use a Mustang K-Member and lower front control arms.The rear control arms on the 87-88 T-Birds are also longer than than the Mustangs IIRC.If you have any questions or pictures just ask,i don't have the T-bird any longer but i do have some pictures like i mentioned earlier.
Later Mark.
mounts
The rear of this one has adjustable upper contol arms and ssm lower control arms with a air bag on the right side. I'm thinking the front still has the stock k-member but with a flaming river rack & pinon setup. Pictures would be very helpfull.
Steve
Pictures
Mark.
Thanks for the pictures. What springs did you use on the front. Like the stance of the car!!
Steve
Steve,
Thanks for the compliment i'm using the stock 4 cylinder springs on the front and rear of my car believe it or not.
Later Mark.
Steve: My 87 T-Bird Turbo Coupe has the factory k-frame. I had to make custom solid mounts to adapt the 460.
I did custom mounts for 2 reasons:
1. I wanted my engine as far back and as low as possible because the theme of my TC is "stock appearing" on the outside.
2. I plan on running this car in the monster mile so I did not want to question the strength of an aftermarket tubular member.(unless I bought the Maximum Motorsport brand)
I used a Van C-6 trans mount to lower the rear of the trans
My front springs are the original 4 cyl. TC ones
You will need a double hump trans cross member....standard 86-93 5.0 Mustang stuff.
Pics with the old "mock up " engine:
I'll post pics of the custom mounts later.
These are pics of the mounts.
Note in the first 2 in-car pics that the 1/2 inch bolts are missing and the engine is slid forward about 1 inch.
The 2 bottom pics show the upper half of the mounts bolted to the new engine.
1 - 10 of 10 Posts
