what is the biggest tire that will fit on a 1/2 ton 1997 4x4 ? i got a killer deal on a set of 35-12.50 tires, what off set is best on this truck, will they fit with out a lift, if not i can put a 3 inch body lift
i had a 89 a few years ago and my 97 sits way higher, if i use them at all, i will have to buy some rims too, just not sure what back spacing to get, and what size if rim..im thinking 15x10i have a 88 f 150 with 35 in boggers without a lift they fit but they definitely take up most the wheel well
???? 35's rubbed on my 91 F250 when i was doing any amount of wheeling. you must have driven the truck like a grandma for them to cleari have a 88 f 150 with 35 in boggers without a lift they fit but they definitely take up most the wheel well
mm..not sure now if it does sit higher or not, but it could easily..lol..Your 97 must set higher than my 96 does i could get 32's on but 33's would require cutting
These are 31's on a 15x8.5 wheel's
I had 35's on my 77 with no trimming and it was defintally not drove easy... Now the fenders are cut for the 38's so i dont gotta worry bout a cut tire???? 35's rubbed on my 91 F250 when i was doing any amount of wheeling. you must have driven the truck like a grandma for them to clear
O yea im just messing with yadifferent body styles clear different size tires..
As always!Lar are you causing trouble again?![]()
Me trouble? pssshhhhh never....As always!
