1 - 12 of 12 Posts
Hi, newbie from the UK, I have a 69 mustang with a 1971 Lincoln 460ci in and a manual tremec 5 speed TKO.
I am looking to swap The TKO to a C6 automatic transmission package as the clutch is too Heavy in traffic and here in the UK the traffic is to much to keep changing gears. So my question is, what toothed flexplate do I need?
I see some flexplates are 164 tooth and some are 184 tooth, what one do I need or how do I tell what I will need.
I will be ordering a performance auto C6 transmission from Summit Racing but again dont know what flexplate I will need
any help much appreciated.
70 torino 429 , 75 ltd 460, either will get you there, be sure to fig out which balance your eng is for sure
It’s getting more difficult, how do I find out what balance my engine is? And are you saying it’s a 164 tooth flexplate I need?
what year is the eng supposed to be?
does it have a counterweight behind the dampener?
does it have one on the backside (eng side) of flexplate?
YES,164 C6 FORD. YOU CAN DO A SEARCH AND FIND CHEAPER PRICES, BUT BE SURE TO BUY A SOLID CENTER LIKE THIS, THIS IS A INTERNAL / NETURAL BALLANCE WHEEL,THUS, NO WEIGHT ON EITHER SIDE
-Rich
Hays 12-060 164 Tooth Internal Balanced Flexplate, 1968-1978 BBF V8
Hays Logo
Part # 42512060
$116.95
$122.95
https://www.speedwaymotors.com/Hays-12-060-164-Tooth-Internal-Balanced-Flexplate-1968-1978-BBF-V8-,287099.html
429, 460, 164 Tooth Count, 29.1 SFI Rating, Steel
Ships Free
On Sale
Tooth Count:164
SFI Rating:29.1
Material Type:Steel
Engine Balance:Internal
thanks It’s a 1971 engine for sure, and the manual trans flywheel\flexplate has NO counter weight on it at the moment.
OK, THEN THE ABOVE WHEEL IS FOR YOU
-Rich
Believe “68” to “73” is 164 I have a “69” an it’s 164. Believe in “74” they went to a 184 tooth flex
Great thanks for all the help, I’ll be getting a 164 flexplate and hopefully using the same starter .
429 460 351M and 400 starters will interchange. till the late 90s stay in the 70's with starter number
1 - 12 of 12 Posts
