I'm having trouble figuring out my total timing and stop the pinging on my freshly built 460 in my 1970 Torino with c6 and 3:50's. The 460 is supposed to be in the 435hp range with 500+ftlbs. It is zero decked with domed forged pistons and worked d3 heads with static compression around 10.3-10.5. It has a lunati 61602 cam, 219 int and 227 ext at 0.50. The distributor is a remanufactured duraspark re curved for the engine to idle at 14 degrees and 38-39 total.
I've set the timing at 14 initial and 38 total and i am running 94 octane (Vancouver Canada) but I get pinging under moderate load. I set my total timing at 38 degrees with vacum advance unhooked and hose blocked at 2500rpm. When I brought it to a shop the mechanic checked it with the vacuum attached and it read 51 degrees which he said is way too much. He told me to run it at 35degrees total and to leave the vacum advance unhooked, said vacumm advance only really helps with gas milage from 2000-3000 rpm range and it is better to leave it off, because with it hooked up and keeping my total timing at 51 degrees is hard on the engine especially in the heat.
But with it un-hooked I'm still getting pinging under load at moderate acceleration.
What's the proper way to check total timing? And as far as the pinging, do I just need to start knocking back my initial and drive it with no vacumm advance? Or should I run the vacumm advance and try and take out some advance at my adjustable dashpot on my distributor?
Mat
Mat
