It's likely the stock crossmember can be used if it's a stick car. If it was an AOD car, the end tube welds can be cut and the member slid forward to line up. To extension housing mounting holes in crossmember may need redrilling.
Took the car out for the first time it hit the rev box at 6200rpm at 3/4 track the time slip say i ran 98mph the calculater say i should run 117mph
I HAVE A C6 3800 STALL 4.86 gears 33 tires but they measure 31inchs before changing gears I want to make sure I'm not missing something thanks...
Have done almost all ford transmissions but for some reason,a C4 has never passed across my bench.The motor is basically a stock 351 W that presently sits in front of a FMX.Anyway,the case and tailshaft have a D4 casting number but haven't checked the date. There is no tag.Anything I should look...
I have a short shaft C6 which SHOULDN'T have been available before 1977, but in looking at master rebuild kits many say up to '76 or 77 and later. The only part I can find that might have a production split like that is the modulator (screw in vs push in?).
The simple (maybe) question is...
has anyone used one of these from speed master I have seen allot of info on them and videos of them being used in street cars and pro mods, I have a 871 blown 545 with fuel injection in front of a custom built c6 with a 4k stall in a 67 custom 500, currently it has a cobra 8.8 trac loc with 4:56...
It's a big block...just the 6 cylinder one.
Turbo 300 inline six, fabricated aluminum head, 800ish ft-lbs going into the converter. Will be using a C6 and 8.8 axle, shortened the 8.8 and converted to use 9" style axle bearings and no C-clips.
Car will weigh around 2800lbs, it's a 70 Maverick...
