1 - 9 of 9 Posts
Howdy, got this truck turning over first time every time now. 1996 7.5 EFI short cab long bed RWD
still want to service the trans and rear diff for this set upright now, as it seems it’s leaking out of every pore it’s got.
Someone said it got rebuilt. The PO said he never rebuilt it
it’s got 310’000 miles to me
what trans do I have? Is there somewhere I can read the stamp. The vin and the plate doesn’ttell me anything besides it’s automatic
what would be the proper service guidelines for servicing the trans on a high mileage truck.
Trans is an E4OD.In my opinion.if the fluid looks and smells good and it shifts ok,don't mess with it.
the fluid looks good nice red and clean, just finding a lot on the floor. Not sure if it’s oil cooler line or what. Looks like the rear main seal or the transmission belhousing
don’t know too much about auto trans missions
If it's red,the leak is probably the pump seal.Trans removal is necessary to repair.Those seals are notorious for leaking and a new improved seal is available. Leak stop additive doesn't work.
great info I appreciate it and will look more into that. Here are some more photos I grabbed while I was dropping off parts at the warehouse looking for the oxygen sensors and I’ll probably pressure wash the trans and engine underside tomorrow or today
i think it might be the rear main seal also
91579
91580
91581
91582
Looks like engine oil but hard to tell because of the dirt.Clean it off as good as you can and put a piece of white paper under it to catch the drips.Report back.
1 - 9 of 9 Posts
