1 - 8 of 8 Posts
New Toy.
Ok here goes I riped the wire from the back of the transbrake button on the steering wheel during loading "Not good" and was trying to see if the button can be removed from the harness for replacement?
I belive it is a B&M 46003 after looking on the net.
Richard
If that is the switch that I'm thinking it is, the back side of the button is a molded piece...probably not much you could do to it other than rig it...
Those buttons are really better suited for a line-lock or spray anyway...
You would be better off with a good adjustable micro-switch...IMHO.
Button
Ok I called B&M and they said there wire is only 2 wires and mine has 3 wires. I belive it was being used for a line lockk and retard button inconjunction with the MSD Ign.
Any Ideas who made it?
Trans brake
Ok it looks as if this is being used for a line lock and retard with the MSD for sure any ideas were to get it?
Toys, Toys and more Toys!
Richard, simply replace the button with one that can be incorporated into your steering wheel that has momentary function. Two terminals are all that's required on the switch.
Dave.
Switch
The switch controals the line lock and the Ign retard in the MSD, not sure just how it is wired but it seems that they will need eather power or ground to each to complete the circute from the 3rd wire.
button
It looks as if i am not going to find a 3 wire button so I am going to get a two wire and use a pair of relays to do the job, can any one recomand a weather tigh relay that will stand up to the abouse of mud and water?
Richard
1 - 8 of 8 Posts
