I hope you guys can help. I know this is not for the FE engine. But I am having a difficult time locating a crank, crank kit or complete engine for my 1973 Ford dump truck. It has a 361 cubic inch. 1 3/4 inch front snout. I would appreciate any help! It had a rod knocking and already has been turned 20/20. Thanks
Thats in the Big truck line of FE they have a longer snout on the crank
and some of those cranks forgerd so they cut the snout down for strokers
HD Ford Truck
F750 and larger grain truck etc
330 Ford SB .LB
car and light truck 331
361 Ford SB .LB
352CLT
360CLT
391 Ford SB .LB
390 CLT
370 Ford SB .LB This maybe a close swap for the 361 crank
429 Ford SB LB 406CLT
427CLT
428CLT this engine has also been used in F700 and light geneator and found using propane and natural gas industrail
Is there a reason that the crank is not regrindable now?
As long as you have a decent crank grinder there is nothing wrong with .030 or .040 under.
you finger nail is about .020 thick and grinding that much off will not hurt the strength ( .020 on the radius and .040 on dia) , but you need to have the radius prepared right so it will not be weak there.
the added thickness of the undersize bearing is added in the steel backing and not in the babbit overlay.
Ron
CRANK
391 crank will fit dont know if you change pistons or not . you dont have to in car engines. sorry dont have any more truck cranks. :)
