1 - 10 of 10 Posts
used 460/429 parts GALORE!!! make offer. $$
i have parts off of 2 460's one is a motor that i had in my boat that threw a rod.
PARTS INCLUDE:
76 460
Block (may need machine work or honing)
crank (may need machine work)
d3ve heads (may need machine work)
marine cam (may need machine work)
stock oil pan, ford blue. good condition
stock oil pan with hole from thrown rod (perfect for rebuilding large capacity racing pan)
2 stock intake manifolds.
1 in ford blue with carburetor attached
1 in black
3 sets of valve covers
3 oil caps
gaskets GALORE
nuts
bolts
thermostat
spark plugs
im sure theres a few things i forgot to mention
i also have a high capacity racing oil pan for 351 cleveland with pick-up tube, windage tray and 4 trap doors
i will take any offers.... really!!!... because if i dont sell this stuff then im just going to take it to the steel mill and get its worth in weight. but i'd rather sell to a car lover in need. like i said any offer will be considered. small stuff will be FREE if you come pick it up.
Just an FYI ~ I'm totally new to this forum stuff but I saw in the rules that "1) You MUST state your price in the ad" among others.
what all gaskets do you have and how much do you have a complete set?
i would have to pull them all out again and figure out whats what, but im pretty sure some of them arent even for a 460. like a set of head gaskets i have that are too small. and some square port gaskets for the intake... but as far as what i KNOW goes to a 460 i have....
valve cover gaskets (rubber)
timing cover gasket set (missing some i believe)
3 sets of valve seats
and a small tool box with other gaskets. ill have to take a picture of it all layed out.
What kind of valve covers do you have and how much? Got any pics of them?
Steve
d3ve. have not taken them off the block so i dont know what the underside of them look like. one of the exhaust valves has been removed just to see how to take them off. if you are serious about buying them i can take them off and take some pix for you.
Are the valve covers factory stamped steel or do you have any aluminum ones? If you have cast aluminum valve covers I would be interested.
Thanks!!
1 - 10 of 10 Posts
