$50 call 360-904-8759
Near Portland,Or./Vancouver,Wa.
These are used Speed-Pro H418P dish top .030 over pistons with stock Ford rods.
6 pistons are real nice,1 lightly scored but might polish up ok and 1 is scored up pretty bad.
6 or 7 of the rods look real good but all should be checked out by a machine shop.
You can buy new single replacement pistons at Summit racing for $14.69 each
Summit part# is STL-H418P
Specs from Summit racing.
Brand: Speed Pro
Product Line: Speed-Pro Hypereutectic Pistons
Part Type: Pistons
Bore (in): 4.360 in.
Bore (mm): 110.744mm
Piston Style: Dish, with no valve reliefs
Piston Material: Hypereutectic aluminum
Compression Distance (in): 1.752 in.
Wrist Pin Style: Press fit
Pin Diameter (in): 1.040 in.
Piston Ring Thickness: 5/64 in. x 5/64 in. x 3/16 in.
Quantity: Sold individually.
Notes: Oblong recessed head .240 inch deep.
Piston, Hypereutectic, Dish Top, 4.360 in. Bore, 5/64 in., 5/64 in., 3/16 in. Ring Grooves, Ford, 460, Each
Dominating the horsepower-per-dollar race.
If you're looking for pistons with an unbeatable combination of performance and value, Speed-Pro hypereutectic pistons are for you. These pistons are manufactured from FM244 aluminum alloy, which contains 16 percent silicon for greater strength and wear resistance. They're also molded in the latest permanent-mold technology to ensure the precise fit and tight bore clearances that today's top engine builders demand. They're ideal for use in high performance street, bracket racing, and oval track racing, and will work perfectly with normal ring end gaps.
