1 - 8 of 8 Posts
Ford 429/460 Stud Girdle (cast iron and properly machined A429)
Ridgeway Racing Association – 3 bar design
Poly Locks and all mounting hardware
Clearanced on underside for rocker arms
Shortened to fit if FMS Tall Valve Covers
Used
$50.00 + shipping
Note: these are NOT user freindly! They are three separate bars held together with a series of 5/16" through bolts. If all you need to do is adjust the lash - then they work fine. If you need to remove them to check spring pressure or inspect rockers and pushrods - then they pretty much SUCK. I am being honest - I put Jomars on mine as I got tired fighting them but if your low on money and need something to get by - then they do work fine.
They will fit all factory 429/460 heads
I don't have pictures yet - hopefully this weekend.
I was using them on A429 heads but I am pretty sure that all the factory ford heads have the same rocker stud geometry (excluding those that were machined incorrectly).
1 - 8 of 8 Posts
