This is a small block application. Heads were previously cut for lockwires and are now going to be surfaced, which will require the lock-wire grooves to be re-cut if we retain the lockwire gaskets.
Has anyone tried running a cometic gasket on a set of heads that were previously cut for lock-wires? In other words, no lockwire...but the groove remains, and now you're using a cometic gasket.
My gut feeling is it would work fine, but that groove is there...and I'm not certain what it might do, so please chime in.
Byron
Yes, that is correct. I don't know how it would work on the aluminum grooves because of expansion and all that, but it's worth a shot. I bought soft copper wire from McMaster-Carr and hammered it into the groove with a piece of aluminum as to keep from damaging the block. Then I used a rough file to smooth it down close. I switched to a mill-bastard file and got it real close. Then I built a thick aluminum block wider than the deck and put handles on it. I used double-sided tape to hold sandpaper sheets on and hand sanded the deck to a super-slick finish. It took 11 hours for the whole process, but I'm glad I done it. I think with the head gasket technology we have now, copper O-rings are a thing of the past. SCE just came out with a nice design that uses a steel ring in-between a metal sandwich. Combustion pressure actually pushes on the ring and makes it seal better. If I ever have a problem with the Cometics, I'm going to try those.
David
