Hey...have a quick question about my 67 f100 it has a 385 series engine...dual quads (550cfm holleys??) SCJ Aluminum heads..built C6 reverse valve body 3800 stall 3.90 locker cal custom bars...custom drive shaft.. seems like this was someone's "track truck" no idea on CUI..
I am assuming it is a solid cam...valve trane is a bit noisy...not nocking..but definitely too noisy...I'm woundering...what the valve lash should be set at? Are all cams and manufacturers different? Is there a "base line" setting?
They all seem noisy maybe the left bank a little more so... 60lbs Oil pressure at idle...cold 35-40 warmed up..
So looking for baseline lash.. thank you.
Steve
Steve
