1 - 8 of 8 Posts
New Comp Cams 973 inner springs. ( Single Inner Valve Springs O.D.: .970"- I.D.: .700"- Seat load: 46lbs @1.750"-# Open load: 126lbs @1.150"- Coil bind: 1.095"- Rate: 134lbs/in- 16 per package) $20.00
New Comp Cams 936 single outer springs. ( Single Outer Valve Springs O.D.: 1.539"- I.D.: 1.125"- Seat load: 149lbs @1.900"- Open load: 328lbs @1.225"- Coil bind: .917"- Rate: 325lbs/in- With damper- 16 per package) $65.00
New T & L 275? (don't know the actual brand) Coated(black), double valve springs w/damper. (Outer Spring 1.56" O.D.,1.120"-I.D.,.220 wire diam., 2.45 O.A height) - (Inner Spring 1.022"-O.D., .730"-I.D., wire diam. .149) With damper- 16 per package (Measurements are approximate!)$175.00
All plus shipping from 47452 Indiana
1 - 8 of 8 Posts
