1 - 8 of 8 Posts
Hey everyone i wanna put my Engine soon together and i need advice if i have to change the Valve Springs on my D00e-r CJ Heads in Combination with a Comp Cam 34-331-4?
And if so what should i buy and does it need machining or other work?
Best Regards Greg
92971
Comp springs recommended are 926-16 or an upgrade duel spring 924-16
Top guides,
Cut spring seats for cups
Single pattern cam is not appropriate for a BBF and will cost you 25+ hp on the top side.
"EMC 2006" 3rd place finisher
Custom ground cams
Customized crate engines
ParklandAutoMachine.com
R-H-P.biz
(253)-988-6648
Log in to Facebook
Discussion Starter · #3 · (Edited)
Okay, thank you so far. Is it possible to identify the installed Springs?
I bought that Stuff in a bundle and maybe the Springs are already others. Not Sure about my Engine Guy here in Germany knows what to Do when i Tell him to cut Spring Seats for Cups.
This is how they looked with removed Springs.
92976
Here's a little valve stem seal trick I found, Use early Small block Chevy valve seals for a LT1 engine (Corvette/Z-28). The rubber seals are smaller then the standard ones due to Chevy loving dual springs in their engines and so they used smaller seals. They're also the same stem size as the all Ford engines except the FEs. The FEs use the one for the BBC LS6 engines. That way you don't have to cut the head stems.
Discussion Starter · #5 ·
Top guides,
Custom ground cams
R-H-P.biz
(253)-988-6648
Log in to Facebook
Hey, i got another Question. What Valve Spring Locks do i need for my Applikation? When i order Springs and Retainers i wanna take New Locks aswell. My CJ Heads have currently an Cup where the Springs sit in. Will this be removed then and i have to cut them?
Discussion Starter · #6 ·
Ok i guess i found it out myself. The Degrees of the Locks Depends on the Retainers and i just have to watch out for the right Valve Stem Diameter. Guess theres no height Differences on the Locks right?
There is, watch for ones that are - or + and standard height.
1 - 8 of 8 Posts
