1 - 9 of 9 Posts
Velasco Billet 4.5 stroke crankshaft with BBC snout
Custom Velasco billet 4.5 stroke crankshaft for a blower motor application. New never ran, only installed in the engine. Uses big block Chrysler rod journals and Ford mains and has the shorter, larger big block Chevy snout for a blower pulley and is double keyed. Also uses the 8 bolt flywheel flange for high torque applications. The crank is turned .010 on the rods due to a mistake at the machine shop, mains are standard. Very nice high performance crankshaft, I paid $3,350 for it before having it balanced. Asking $1,800 plus shipping from Oak Grove, Missouri. Will accept paypal if you cover the 3% fee. Thanks, Chris, [email protected]
I had aluminum 6.8 inch Brooks rods with 4.5 Arias pistons, bobweight is stamped 2425. A steel rod for a Chrysler would also work or another set of aluminum rods. This setup was designed by Carrol Carter at C&C Motorsports and said its a stronger setup than the standard Chevy style rods for a blower motor. Chris
1 - 9 of 9 Posts
