1 - 10 of 10 Posts
Im looking for a 429 crank with a 1.375 pilot in or around the Oklahoma city area thanks
429 crank
I have two cranks in my shed and will have to check the pilot size. I think they make a sleeve to down size these as well. I'm located in the colorado (denver )area.
If you or any of you know of a sleeve then let me know I have a good 429 crank with the bigger pilot but since i am switching from a 460 to a 429 my tci converter won't fit It has the 1.375 pilot and the 429 crank is diff. thanks
A couple of ideas
You must have a very early 429 crank if it has the 1.878 pilot. I think in 70 they started using the 1.375.
Here are a couple of suggestions.
1. Have a machine shop make you a ring to fit.
2. Change it to a later crank with a 1.375 pilot.
3. Change the converter. The 428 C-6 used a 1.878 pilot
What stall are you running? I might have a converter that would work for you.
2
Guest
pilot
dont think the 429 crank is bored deep to take smaller pilot. flywheel on crank try conv. if it fits fluch to wheel then a bushing will work
Thanks guys i went ahead and got a crank from my machine shop with the right sizes pilot.
Shane
1 - 10 of 10 Posts
