1 - 3 of 3 Posts
i am looking for an aluminum water cooled 385 series block. i would like bores that are good for 4.600"+. A 10.3" deck height is preferred but i could use an 11.2".
I am only using 10 bolt A-heads on this deal so i dont require an 18 bolt block.
i am also putting a 4.5 stroke in this deal in case any one cares.
thank you,
barry
360-580-1085
I have a C&C 11.2 water block. It was damaged on #1 and #5 cylinders near the cam tunnel. Lost the ends of those two sleeves. The oil pump mounting bolt got 1/2 taken out. No water areas are damaged. The cam tunnel should be welded to support new sleeves in that area. It has a 4.600 bore, Jesel keyway lifters (.937). The exhaust lifters have offset pushrod seats. Comes with all plugs, steel main caps/with studs, bolts, nuts.
If you are interested a project/block, I will take pics and e-mail them to you. If not, let me know. The block is in Bay Area, Calif.
I am very interested in this deal.
1 - 3 of 3 Posts
