1 - 9 of 9 Posts
Im looking for 460 pistons 30 to 60 over.I want to run pump gas no racing fuel. No junk please. I just got burned on a motor deal.Just trying to put it back together. THANKS
Just depends on the price.Not looking to spend to much but dont want junk.Used in great condition will work. It all depends on the big$$$$$$$$$$$$ THANKS
i will take a look. I think i have a good used set of .030 over stock rebuild cast pistons that i could make you a good deal on
barry
THANKS. I will be back online around 12:00 today. Block is at the machine shop now.Long storey why i need pistons.Lets just say you cant trust anybody anymore.If it helps my # is 1-540-297-6688 thanks chris
I have a set of speed pro H535cp I think is the #, they are the hyperuetectic in .030 on DOOE rods. One piston hit a valve after a few runs and I have the new piston (it has coated skirts, the other seven do not) so you just have it put on the 8th rod and a good set is ready, you can see where the rods were balanced also. They have almost no wear sign on them, couple faint lines is all. I have 200.00 into them. If they will work for you that would be the price plus shipping. I can take pics if need be. I ended up with another set of new ones all coated skirts so I am using them is the reason for selling. Dan Parker St. Anthony Idaho
have .030 forged TRW/Speed Pro dish piston on rods with new ring set.. very low use on pistons $300 Dan 315 455 7316
The picture did not turn out as well as I would have liked but if it actually loaded up it will be a first for me.. I can always email more if need be. Thanks Dan
1 - 9 of 9 Posts
