1 - 9 of 9 Posts
Needing to get bids for a street,pump gas, 15psi boosted 532.
Bores: 4.4393 - 4.440
Blue Thunder w/Ford Ex. 2.25x1.88, 68cc measured.
Looking for 9.0 to 1 compression w/ 1/16, 1/16, 3/16, pin out of ring land.
Need 4.3 forged crank, 6.8 rods, pistons, rings, bearings, flexplate, & balancer. Balanced internally preferrably.
PM me please.
Thank you, Marty
Another mistake of original post :oops: : Flexplate is not needed, this will be a stick car so please scratch the flexplate.
Thanks, Marty
Marty,
Reality is that any of the vendors here are probably within $50 or so of each other. Pick one of the guys you are comfortable working with & go for it. With everything you will end up spending on that engine, $50 or even $100 difference in price isn't worth it...
For instance, I bought a kit for my 557. The pistons I got were flat tops, but did not have an exhaust notch. My engine assembler had to locate, then notch each one because of the big cam I got. Difference was, the Probe pistons I got were a tad cheaper than the Diamonds I could have had... I can guran-friggin-tee you I spent more having them cut than the difference in piston price!
JMHO,
John.
my question was never awnsered,do you guys have all of this,and just need asb?
or do you also need all of it?
-rich
1 - 9 of 9 Posts
