1 - 16 of 16 Posts
Want To Buy: two 460 truck motor mounts, the clamshells that bolt to the block and fit over the insulators, I have the frame stands and insulators just need the clamshells. Thanks in advance for your help.
is it this part ..the upper top one you are needing
Thank you for the reply, but that is not the parts I need, the engine mounts (Clamshells) are for a 1976 2 wheel drive F150.
mounts
are you needing the ones that the bolt goes through the mount?pat
460 motor mounts
Similiar, it has a bolt that goes through it like that mount, but the bolt pattern where it bolts to the block has three holes. Thanks for the reply..Rick
Pat, 460 mounts
Pat, Yes the mounts that I need have a bolt that goes through them and it has three bolt holes to bolt to the block, thank you for replying..Rick
mine do mount with 3 holes to the block- let me know if they are what you need, as i said they are of no use to me. they came from a 77 ford 4x4 with a 72 lincoln 460 in it) i took the motor with block plate mounts on it from a running truck. take a good look because they are yours if u need them-
these don't even have the correct bolt pattern for a 429/460 since they came off of a 351M/400 engine just look at the picure of em sitting on the wheel competely different block pattern
1 - 16 of 16 Posts
