1 - 6 of 6 Posts
Hey guys, maybe someone has these laying around.
I need to complete my setup for the 460 swap into my 68 F-100. They are factory parts. The parts I am talking about are the frame perches, motor mounts, and engine mounts. Three pieces per side from 73-79 2wd F-series pickup trucks.
I actually have the frame perches already, and I can get the motor mounts from the parts stores, but I need the engine mounts to complete my setup.
Are they made or rubber? 1 hole on each corner and a stud in the middle. If so i think i have a set. If this is not what you are talking about then it goes to show you what i no.
You may think I'm nuts,but I used the motor mounts from a 390 ltd to put a 460 in a 79 f150 that came with a 351m. Had to drill the holes where the mount bolted to the block and used a 1/8 inch washer between the mount and stool.Worked perfect,ran it for years before I pulled the motor and sold the truck.Back when I did this the 460 mounts were exspensive and the 390 mounts were only 15 bucks each.Some of that good ole backyard ingenuity! lol
As a matter of fact Charlie Evans has this motor with the mounts still on it if he hasn't torn into it yet.
Ihave the clamshells that mount to the motor they came out of my 78 F250 with 460 if you want them $25.00 plus shipping 49615 zip
1 - 6 of 6 Posts
