1 - 6 of 6 Posts
ok so ive hade these weld prostars up in the garage fora a couple years,(nib by the way)these are the old school welds they have lettering machined next to the lug bolt holes.any way when bolted up the hit the side of the caliper,the spring of the outer pad to be exact.these are 15x4 for some front runners.any solutions?
the rim hits on a machinedflat portion of the rim,ive got 15x7 that are the same way?just wonderin.....
Like faststang said you could put a spacer behind the wheel or If you have some weld thick washers you could try them also to get clearance you need. I done my that way, It works.
I've got 5" Pro Stars in the front and they were hitting on the caliper mounting bolts. I ground off most of the side of the bolt toward the wheel for clearance leaving just a thin portion of the hex for a wrench to grab.
Gary
Not exactly the same but on my 96 cobra the rear calipers were interfering with my weld pro stars. I dont like the look with wheel spacers so I used a flap wheel on 4" grinder to take down the calipers some on the outside and milled down the pad where the bleeder screw goes.
All in the name of a cool set of wheels.
1 - 6 of 6 Posts
