Have a 1997 Ford F-250 with a 460 engine. Starting in 1996 all Ford vehicles sold in the US have the EEC-V system. I've looked all over and cannot find a code reader. I can find them all day long for the EEC-IV system but they only go to 1995.The plug in on my truck has 3 blade connections and a single wire blade connection under the hood on the drivers side.
Thanks,
Discussion Starter · #3 ·
OBD 1 reader if you really think you need to read the codes.
Sent from my SM-N950W using Tapatalk
Thanks, that is the one I have. On the bottom of the reader it says 1981-1995. My truck is a 1997. Why wouldn't I want to look at the codes?
On the 460s, Ford used OBD-1 up to 1997 and only changed when they introduced the SuperDuty in 1997.
Not sure how useful the codes are as they are pretty rudimentary in OBD-1 and you normally know what this issue is before scanning. I have yet to find a need to pull codes on mine.
You might, however, be able to pull something if you happen to get a FORD bus scanner for a song. The bus runs separately from the OBD-1 and is usually accessed in the engine compartment via the diagnostic port. The closest aftermarket tool that I am aware of that can also access the pcm/ecu is the quarterhorse.
