I'm putting togeather a few parts to complete the bottom end of my 545, I've got a Canton main cap girdle, and I'd like to put in a Kaase oil pump as well. I've been told that the Kaase needs a 6 1/2" pump pocket. The car is a 66 Fairlane that has had a Rod and Custom crossmember and rack and pinion conversion installed which I'm informed needs a rear sump setup the same as a fox body.Has anybody had a similar combination and if so, what pan did you use?
