Im going to be making some changes to my setup and was seeing what everyone has had luck with..? I know I could call and spend a good chunk getting a custom grind and i might end up doing that but just seeing what you guys are running.. Thanks
MAN!!! That was a good one! HA! I just noticed your running 9.0s. I'm almost there with my "junk". REAL close!I think Wal-Mart sells cams now.
Did you not notice the OP has Pro-Comp heads ?I see absolutely NO reason to be antagonistic unless you have an oversized ego which needs to be put into check or you're simply looking for an argument; neither one is a reason which is worth a damn.
I'm just a Dick thats all.I see absolutely NO reason to be antagonistic unless you have an oversized ego which needs to be put into check or you're simply looking for an argument; neither one is a reason which is worth a damn.
Well said Jon!I'm just a Dick thats all.
I like steak yet some people prefer Skippy peanut butter and that is their prerogative ... this was a question about CAMSHAFTS.Did you not notice the OP has Pro-Comp heads ?
G-![]()
6,173 posts........Man, that's a LOT of P/C headed motors! LMAO! GO GET 'EM Jon!I'm just a Dick thats all.
