1 - 10 of 10 Posts
· Registered
I've always used straight 30W oil for break-in (most cam manufacturers suggest this). I've never lost a cam.
· Registered
Re: rotella
70spoiler said:
can i use rotella al the time in my 466 solid cam engine? i buy it anyhow for my powerstoke. jack k
Absolutely. I run it in my PSD as well as the race car, and I'm going to start to put in my cars as well. Great oil at a reasonable cost.
· Registered
I use straight 30 as per cam companies rec
I have used others too. 30 seems to work good. I have just been using the normal valvoline that you can get at wal mart. With a bottle of eos. If I am running over 300 psi open I only run the outer springs and then add them later. Big thing that I have found is to make sure the engine starts right away with out cranking it much. The cam isn't getting oil while cranking and I have seen that wipe some cams out. Prime the carb, make sure your dizzy is close to where it needs to be.
Kyle
· Registered
Been using Rotella 15W40 since 92 in all of my race engines. It's the only oil, short of synthetic, that I found will hold up to the temps without dropping pressure too much as the oil warms up.
1 - 10 of 10 Posts
