you got it imo . for Holley get a squre bore one
Published dyno tests are run at wide open throttle anyway so, that is not a good indication of part throttle performance. The iron intake for the ThermoQuad with that carburetor will be your best part throttle performer.As the headline says. What is the best low end torque intake? What I have now is a D6VE Spread bore intake. I want an intake that will give good low end torque from idle to around 3500 RPM. I'm using this on my dually 460. The goal of this motor will be to get good low end torque & maximum MPG's. It doesn't matter whether it's Aluminum or cast. I've found intake dyno test for small blocks but can't find one for big blocks. Do's anybody know if anybody has ever done a dyno test for big block intakes? I'm going to be using a stock Holley carb on this setup.
Not enough to make your dually even blink.How much weight would I save?
