Next Topic >> Return to Index
Whats the best regulator for mechanical fuel pump?
January 10 2006 at 12:30 AM
No score for this post James (Login Fairlane62)
from IP address 65.255.74.49
I have a Carter M60882 mechanical fuel pump which is rated at 120 gph at 7.5-8 psi. I was able to get by with the higher pressure while the carburetor inlet needles were new, but now they are beginning to seep past creating an intermittent rich condition.
I have 8 AN lines from the fuel cell to the pump, and currently 3/8 from the pump to the carburetor. I'm familiar with using regulators with electric fuel pumps, but what would be the best regulator to run with a mechanical fuel pump, in this application?
Thanks,
James
Author Reply
Lem Evans
(Login l-evans7)
69.166.129.47 I have never used the ...
No score for this post January 10 2006, 12:53 AM
M60882 carter pump . We have used the M61044 172 gpm pump on one and two carb engines with good results w/o a regulator . It is rated 6-8 psi .
If it used to work w/o the reg it still should . I'd check the float level and the needles/seats 1st .
This message has been edited by l-evans7 from IP address 69.166.129.47 on Jan 10, 2006 12:55 AM
James
(Login Fairlane62)
65.255.74.49 Worked for about 2 months
No score for this post January 10 2006, 1:08 AM
Lem,
It worked for about 2 months with the new carburetor, then it sat for a month while I was out of town, now it will randomly flood, but it most typically happens after or during a full throttle run. The Carter liturature said that it should be run with a regulator, so I figured that was the problem.
Thanks,
James
Ken 67 Wagon
(Login FE_rex)
70.246.25.182 Holley regulator
No score for this post January 10 2006, 7:14 AM
I ran a standard holley on a 302 with a carter high volume pump.
The carter "street" pump was supposed to NOT need a regulator. I fought with a stumble at launch for 3 weekends then put on a fuel pressure gauge. It read 10-psi. I was suprised the car was even running. The needles and seat could hold everything except a 4000 rpm launch. No problems after installing the holley. Made me a believer in fuel preeure gauges for ANY kind of pump.
FoMoCo
(Login 68460)
24.11.111.122 I run
No score for this post January 10 2006, 7:28 AM
the same M61044 172 gpm pump w/o a reg and have had no proble.On cold start up my liqiud filled gage goes to 10 psi and once warm back to 7ish.
Greg Havemann
(Login gregh429)
128.227.137.9 Liquid filled pressure gauge.
No score for this post January 10 2006, 4:14 PM
If the vent is not opened on the liquid filled gauge, it will read lower as it warms up.
Greg
Current Topic - Whats the best regulator for mechanical fuel pump?
